Stick Build Sabach 35 Profile
Postby phjoker » Sat Mar 19, 2011 5:00 pm
Well after stick building the Lazy Bee I decieded to Stick build another plane. This one is a 35 sized profile designed around the Sabach style Plane. This one is being built for Electric. I am building 2 at once, the first one is for Haggie since he did the lights and covered my bee. Now he can cover this one also :banana
This is the Parts Sheet.
Here are the ribs cut out with the paper still glued on.
Wings are the best and the Fastest to build. Make sure the ribs are level and you are good to go
**Can You Smell The Jet Fuel Burning**
phjoker
Re: Stick Build Sabach 35 Profile
Postby phjoker » Sat Mar 19, 2011 5:08 pm
It Took a couple of hours to get the wing done
Almost done
While the wings are drying I started the Ailerons
Ailerons done
Check out the new wing joining system that they came out with. If you look the joiner it is attached to the main spars and has a hole in the middle for the carbon fiber tube. The back of the wing will have anti rotation dowls. You can make the rwing removable but I am not. It's a small profile
More to come stay tuned...
phjoker
Postby Greg_nj » Sun Mar 20, 2011 6:33 am
I was thinking of building one of these too. Did you buy the kit or just download the plans?
Greg_nj
Postby phjoker » Sun Mar 20, 2011 6:56 am
I downloaded the plans. The guy wanted somewhere around $80.00 for the kit.
For $95 dollars I got all the wood and carbon fiber tube to make 2 kits. It just takes some time cutting out the pieces.
These are the pieces that have to be cut. I cant see paying $80 for those few pieces, some sticks and 3 sheets of balsa
phjoker
Postby Greg_nj » Sun Mar 20, 2011 7:07 pm
Where did you get the tubes from?
Greg_nj
Postby phjoker » Sun Mar 20, 2011 7:14 pm
It was a kite building website. They had a ton of different sizes in all sorts of Lengths.
I will have to see if I can find it, I can't remember off the top of of my head what it was.
phjoker
Postby Sal A » Sun Mar 20, 2011 8:30 pm
So are you cutting the wood yourself WOW - thats one thing i would like to try - just no time . lookin good
Sal A
Postby phjoker » Mon Mar 21, 2011 3:09 pm
It's not that bad. But then again I am building 2 at once. So yea it was a lot of wood to cut. No more stick building for me. I will stick to the kits after this one.
phjoker
Postby nalby » Mon Mar 21, 2011 3:25 pm
If you don't mind me asking where did you get your balsa and Fiber from? I am interested in building one of these myself
nalby
Postby phjoker » Mon Mar 21, 2011 5:34 pm
I got the wood from http://www.nationalbalsa.com. They had the best prices around at the time, but they are closing their doors shortly going out of business.
I got the carbon fiber tube from http://www.goodwinds.com/. A ton of selections.
Elevator and stab are done.
Elevator/Stab
The nose section of the profile is made out of 1/4 balsa wood with A piece of 1/16 ply laminated to each side. Below all the sand bags is that nose section being laminated.
Nose
Now while the nose section is drying I am cutting and dry fitting the fuse. I don't want to glue anything untill I get the nose section done and fit everything first. The carbon tube does not get glued in untill the fuse is built. For now it's there for a fitting reference point
Fuse
phjoker
Next
Users browsing this forum: No registered users and 12 guests
